Need Help between Graphic cards
ahmedsalmanbajwa
107
4
4,595
So i just held a post about which graphic card i could use in my Optilex 780 to play at least GTA 5.I am on a budget and can't afford a new PSU or change Bios
Cards- GTX 1030 vs GTX 750 Ti
Please tell me which i could have with valid reason and if you have a better card please do tell
PC SPECS
Please reply quick
Well the 1050 won't fit and will also probably burn the pc,also the power consumption of that thing is way too high for me.
The only card for AMD that i heard will work is the RX 460 i think,but in general which card is better?
i have had both AMD and nvidia , the overheating is about the same .. although if you have watercool it makes a difference in the overall heating thing .. with AMD you can get more processing power with the same money .. if you wanna play GTA 5 ...
Yeah no water cooling,but from what you are saying the RX 460 is my best bet???Sorry i am new to getting gpus and how they work
yes , i would assume a rx 460 will run a better GTA 5 than a 1030 ..
Well I used two different sites to check which is better and this is the result
Site A
Site B
Take a look for yourself mate
Latest posts
