[SOLVED] Need help booting from SSD; PCIe M.2 SSD not showing in bios
jhayat
65
Hi all :)
Computer #1 is an ASUS x299 TUF, which has NVMe support; there are NVMe slots on the board and I can boot into W7 from my SSD, which is in one of those slots.
Computer #2 is an ASUS P9x79, which has no NVMe support; there are no NVMe slots on the board; W7 is installed on a SATA HDD. No issues there.
I would like to ditch that SATA drive, and run W7 off of a Samsung EVO NVMe SSD on comp #2
First thing I did is the hotfix so that W7 will see the NVMe:
https://www.sevenforums.com/drivers/417318-nvme-driver.html#post3412377
I purchased an ASUS PCIe adapter card, and put the SSD in there. Windows sees that SSD, and r/w works as expected.
I did a migrate of the os to the SSD using AEOMI Partition Asst., and it seems to have worked properly; if I open the drive within windows, it looks as it should (Program Files folders, Windows folder, etc.)
But I can't boot into the SSD. The BIOS doesn't see it. Yes, I have the latest BIOS vers for that MB :)
I found this:
https://www.tenforums.com/installation-upgrade/129763-pcie-m-2-ssd-not-showing-bios.html
I created a UEFI Bootable USB Flash Drive using this:
https://www.eightforums.com/threads/uefi-bootable-usb-flash-drive-create-in-windows.15458/
That looks like this:
http://jeffreyhayat.com/temp/ruf.jpg
Not sure if that's correct, but that is what Rufus gave me.
So, I followed the instructions in the 10forum post.
1) Tho I do not have 'Storage Config' in my BIOS, I have 'SATA Config', and that is set to AHCI
2) I disabled CSM
3) I changed secure boot to other os
4) There is no option to clear secure boot keys under Key Mgmt
5) Saved
So, here is where I am stuck. And what does the UEFI Bootable USB Flash Drive do for me here? I am not looking to install W7; only to get the BIOS to see the SSD.
Any ideas on what I can try next, or what I am missing?
Thanks in advance.
D
Yeah that’s probably not going to work it will work as a normal drive under windows but you won’t be able to boat from it. even with the PCIE card. Only the newer boards with the NVme slots Can actually boot. In your case for the second computer I would get a sata SSD
Thanks.
I found a guy on another forum who modded the BIOS to get this to work. Same MB. I am considering giving it a shot.
If something gets screwed up, will I be able revert back to the current BIOS?
