need help building a computer 200 bucks or less
At that kind of price level, you're most likely better off looking for a used/refurbished system with a not-too-ancient mid-range CPU, and maybe adding a low-power graphics card to it. There are some used small form factor business PCs on eBay with 2nd and 3rd-gen i5 processors for around $100 or so, that you could then add something like a GT 1030 graphics card to. Just make sure the PC has a PCIe x16 slot available for the card, and if the case is a small form factor (SFF) size, go with a low profile GPU. Ideally you would want it to have a 300 watt or higher PSU, but a GT 1030 is only a 30 watt card, so you might be able to get away with less than that. A used PC with something like an i5-2500 that has had a GT 1030 added would...
Too little budget. I gave it a shot:
CPU: Intel - Pentium G4400 3.3GHz Dual-Core Processor ($54.95 @ Amazon)
Motherboard: Gigabyte - GA-H110M-A Micro ATX LGA1151 Motherboard ($44.99 @ Amazon)
Memory: Patriot - Signature Line 4GB (1 x 4GB) DDR4-2400 Memory ($47.99 @ Amazon)
Storage: Seagate - Barracuda 250GB 3.5" 7200RPM Internal Hard Drive ($14.50 @ Amazon)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case ($19.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($44.99 @ Amazon)
Total: $227.41
Generated by PCPartPicker 2018-02-27 12:23 EST-0500
At that kind of price level, you're most likely better off looking for a used/refurbished system with a not-too-ancient mid-range CPU, and maybe adding a low-power graphics card to it. There are some used small form factor business PCs on eBay with 2nd and 3rd-gen i5 processors for around $100 or so, that you could then add something like a GT 1030 graphics card to. Just make sure the PC has a PCIe x16 slot available for the card, and if the case is a small form factor (SFF) size, go with a low profile GPU. Ideally you would want it to have a 300 watt or higher PSU, but a GT 1030 is only a 30 watt card, so you might be able to get away with less than that. A used PC with something like an i5-2500 that has had a GT 1030 added would be a much more capable system for gaming than anything that could be built for around $200. Ideally, you should look for one that also has a copy of Windows installed, so that you shouldn't need to deal with that.
That doesnt seem possible, unless he is willing to buy used parts
