Build Advice Need help building a gaming pc
Jun 30, 2022
18
5
15
Reactions: Why_Me
Looks ok as it is but there could be room for improvement. What is your budget for the build and what is your primary usage?
Also, you are missing a case and storage.
Im going to use it for heavly modded skyrim and some newer games. As for case and storage, im gona use my old hdd 1 tb, and for case ill go to local pc shop and let him assemble it with a case he finds suitable. Budget is around 1000-1500 £
Also I’d consider dropping the 5800x for a 5700x. 5700x should give you similar performance to the 5800x. That should allow you more room for other components or maybe lets you upgrade the gpu to a 3070.
I was debating should i go for lower end cpu 5700x but i tought if i buy the 5800x one i wont need to replace it if i decide to upgrade later on?
Reactions: Hidanscythe
Skyrim and its mods are very GPU demanding. I would go with something like this...
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor | £271.98 @ Aria PC
CPU Cooler | be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler | £71.00 @ Technextday
Motherboard | Gigabyte B550 AORUS ELITE V2 ATX AM4 Motherboard | £115.40 @ Technextday
Memory | Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory | £140.84 @ Scan.co.uk
Video Card | MSI GeForce RTX 3070 Ti 8 GB VENTUS 3X Video Card | £663.48 @ Ebuyer
Case | Corsair 4000D Airflow ATX Mid Tower Case | £80.99 @ AWD-IT
Power Supply | Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply | £109.99 @ Amazon UK
| Prices include shipping, taxes, rebates, and discounts |
| Total | £1453.68
| Generated by PCPartPicker 2022-06-30 18:00 BST+0100 |
200A board with good VRM to handle the CPU. By the way the difference between 5700x and 5800x is a mere 6 quid at the time of posting. Rock solid cooler, low profile memory with adequate speed and timing and good fit under that cooler, well ventilated case to keep the thermals in check on heavy load, good quality PSU and a strong card.
You are certainly going to need more than that small AIO for a 5800X. 240mm at minimum would be my suggestion.
I run my 5800x with a Vetroo V5, in an ITX case, and have had 0 issues. Also the H100i is a 240mm.
Type|Item|Price
Power Supply | Corsair RMx (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply | £99.98 @ CCL Computers
| Total | £1443.67
| Generated by PCPartPicker 2022-06-30 17:49 BST+0100 |
I would argue that a card with more Vram would be a better idea for modded skyrim, as depending on mods, it can eat v-ram quite quickly.
To the OP, you do not want to use a HDD, for your main drive, in this system. It truly deserves an SSD, and I have included one in the build.
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor (£271.98 @ Aria PC)
CPU Cooler: Corsair H100x 57.2 CFM Liquid CPU Cooler (£61.22 @ Amazon UK)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard (£81.25 @ Amazon UK)
Memory: Kingston FURY Renegade 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory (£129.01 @ CCL Computers)
Storage: Western Digital Blue SN570 1 TB M.2-2280 NVME Solid State Drive (£72.78 @ Amazon UK)
Video Card: Gigabyte Radeon RX 6800 XT 16 GB GAMING OC Video Card (£706.90 @ Amazon UK)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case (£79.50 @ Computer Orbit)
Power Supply: Corsair RM (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£88.48 @ Box Limited)
Total: £1491.12
Generated by PCPartPicker 2022-06-30 18:14 BST+0100
I agree, but the usage it reflects is mostly not real. its what has been allotted to the game. If you use a stronger card, the usage will climb even more, but the game doesn't usually use all of it. Skyrim mods like VRAM but there is a diminishing value of return after a certain point.
View: https://www.reddit.com/r/skyrimmods/comments/kxrc9t/how_vram_really_works_in_skyrim/
Also, I can see that it is more optimized for Nvidia cards...
View: https://www.reddit.com/r/Amd/comments/pwxe2i/the_new_6000_series_gpus_and_skyrim_se/
Agree with the storage part...
Type|Item|Price
Storage | Corsair MP510 480 GB M.2-2280 NVME Solid State Drive | £49.99 @ AWD-IT
Case | Corsair 4000D Airflow ATX Mid Tower Case | £89.00 @ Computer Orbit
| Total | £1511.68
| Generated by PCPartPicker 2022-06-30 18:42 BST+0100 |
Hmm does monitor help with card selection im using MSI Optix AG321CQR Curved Gaming Monitor - 31.5 Inch, 16:9 WQHD (2560 x 1440), 2K, VA, 165Hz, 1ms, 1500R, FreeSync Premium, HDR, RGB, DisplayPort, HDMI, Wide Color Gamut, Less Blue Light, Black : Amazon.co.uk: Computers & Accessories
My brother is strongly against radoen graphic cards but as i look at it in midrange they are quite similiar.
Would dlss affect me?
Monitor should run both card fine, but I am not too sure about AMD for the Skyrim mods. This reddit post suggest that the initial AMD drivers were not optimized well. It has been long since, so maybe stuff has changed. Maybe, someone who has run that combo recently should know better...
Type|Item|Price
| Total | £1453.68
So far i am leaning towards this setup just need to cough up all my savings 😀
I am planning to add an ssd hard drive next month.
Question can i have 2 hard drives on this setup?
Yes, you can. Although, make sure that you have only the SSD attached when installing Windows. If Windows detects a second drive during installation, it has a nasty habit of unloading and creating a system partition on the second drive. Attach the second drive after Windows is installed.
Oh thats good to know i was wondering why my pc kept making weird files on my second drive.
