Hello one and all,
I have my PCs backed up to a 12TB NAS, but that NAS itself needs to be backed up. I first thought I could use an old 945GNT mobo and ran into a 2TB limitation. Then I pulled out a newer used PC from my stock with a DP35DPM mobo and ran into the same limitation on the RAID size with Winserver 2003.
A friend of mine suggested I overcome the limitation with a dedicated RAID controller, but they are quite spendy and seemed overkill for a backup to a backup.
What can be done with my E6750/DP35 to utilize the six SATA ports with six drives to create a 12TB partition like my NAS has?
Thanks....
Thanks....
