Hi, guys..
So I'm trying to build a custom PC and my budget is $1800.
I researched a lot about all the components that I have chosen but I still have some doubts if these components are compatible with one another or after building my PC will not run fast or stable.
Components:
1. Motherboard : MSI Computer ATX DDR4 3000 LGA 2011-3 Computer Motherboards X99A GAMING 7 - $299.99
2. Case : Corsair Graphite Series 780T Full Tower PC Case - Black - $182.55
3. CPU : Intel Core i7-5820K Haswell - $399.96
4. Graphics Card : MSI GTX 970 Gaming 4G Graphics Cards - $348.94
5. Power Supply : Corsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 744 Power Supply CX750M - $85.89
6. Memory : Crucial Ballistix Sport 16GB Kit (8GBx2) DDR4 2400 - $124.99
7. Cooler : Corsair Hydro Series H100i GTX High Performance Liquid CPU Cooler CW-9060021-WW - $109.99
8. Hardrive (SSD) : Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD - $164.00
9. Thermal Compound : Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound, 3.5 Grams - $6.95
These are the things I have come up with until now... I would really appreciate any feedback/suggestion/advice regarding these components, like if I should consider some other component rather the mentioned above and even if I buy something cheaper that my build will work good, fast and stable...
It would be really great if I could minimize my cost overhead even if its just a little bit without losing any performance or sacrificing a feature..
EDIT 1:
This is custom PC is for gaming and mainly will be used for programming and other stuff..
Again, I would love everybody's feedback for this.
Thank you in advance
Components:
EDIT 1:
