Here are the parts I'm thinking about choosing for it:
AMD FX 8350 4 GHz
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4904561&sku=A79-8350
ASUS M5A99FX Pro R2.0 Socket AM3+ Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3184372&sku=A455-8426
Corsair Vengence 8 gb x1 1600 MHz DDR3
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2952326&sku=C13-5715
Seagate ST1000DM003 Barracuda 1TB Hard Drive - 7200RPM
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=744346&sku=TSD-1000AS7
Cooler Master Elite 430 Mid Tower ATX Case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6430030&sku=C283-3122
SolidGear 650W Power Supply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7906003&sku=C15-1024
How do you all think this build looks? Is there anything that i've selected that's rubbish? Any and all thoughts on this would be greatly appreciated since this is my first solo build. This build pretty much takes up my budget. After next day shipping it comes to $610. But I will consider anything that you all have to tell me. I'm only getting the 1 stick of ram because i plan on adding an identical 8 gb stick later and dual channeling a total of 16gb when i get more money. And I also went with the 1600 MHz because everything i've read says that there's not a huge difference in 1600 and 1866 MHz.
AMD FX 8350 4 GHz
