Need help buying.
haxs101
179
I'm looking to buy a 1366 processor (i7). I also need to buy a motherboard, memory, and a psu. all for around 750$ max. I been looking and comparing, and I need some help.
I got the rest of the components.
Thanks, Xion.
will you be using a high-end video card for gaming or other activities? this will decise in what power supply you will need, as for the Mobo/CPU/RAM, the following 3 should suffice...
CPU/RAM Combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.364591
Motherboard with USB 3.0 and SATA 6
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
Total comes to $684.97 which leaves room for a 650w power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
69.99 after mail-in rebate = grand total of 754.96
I got a single 5870 already.
you could also dumb-down the RAM and/or motherboard to save a little $$$ but you wouldn't be saving too much and in my opinion, all the items i posted are very good quality items from good quality brands...
