So I just changed my really old 17inch LCD DVI monitor to a new widescreen 23"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
on my NVIDIA options it only has an option for 60 hertz. How can I change it to 75 hertz? My really old monitor supported 75hz. it says the new monitor supports 75 hertz under the details tab on Newegg. I also didn't mention I am using DVI and the highest resolution. I tried lowering the resolution and checking to see if the 75hz option is available however it is not.
If you go any lower than the resolution I am at, it gets very distorted and there is poor image quality.
btw I unchecked "hide modes that this monitor cant display" under properties/settings/advances/monitor.
