Question Need Help Choosing a Motherboard
Jul 18, 2019
15
So Im looking to build my first PC.. Considering my budget ill go for a Ryzen 5 2600 and pair it with a gt 1030 that i already have or ill go for an R5 2400G and then add a graphics card later on.. I need some advice on some budget MB preferably under $100 that will be compatible out of the box with either of these processors and will not need any bios update.. please help..
Jul 18, 2019
15
Well i have a VGA monitor.. i could use my tv but thats a 55" screen.. i guess i could use it as it is with the 2600 and then in a couple months i only will need to get a smaller monitor and a better graphics card.. instead of getting the 2400G now and then having to switch to a better CPU, graphics card and Monitor in the future..
Jul 18, 2019
15
yes.. are there any other MB I could consider.. i dont need any extra features.. just need to get the CPU running.. im thinking B450M DS3H from Gigabyte so that i could allocate my budget to something more important.. will this MB run out of the box or will i have to update the bios?
