Question Need help choosing an AM5 mobo.
KukKaBubBa
4
Hi everybody actually I hav the following pc
ASUS TUF GAMING X670E-PLUS
RAM G.Skill Flare X5 DDR5 2 kits with 2x16GB 6000MHz CL36 each
CPU Ryzen 7 7700X 4,5GHz + Dark Rock Pro 4 135mm
PSU Be Quiet Pure Power 12M 750W
CASE be quiet! Pure Base 500 Midi-Tower
VGA ASUS TUF 4070ti
I feel really disappointed with my actual Mobo and I want to change it (probably along with the RAM which I do not like too)
I was looking to MSI X670E MAG Tomahawk but I read about many problems with bios (which is one of the main reasong why I want to trash my Asus Mobo)
I would buy a mid-priced mobo (200-300 €) with PCI-E 5.0 and the possibility to undervolt the CPU
could you please pointme in the right direction?
Thanks a lot
VGA ASUS TUF 4070ti
Thanks a lot
What is disappointment ?
Have a look at this one. Most used by extreme overclockers
https://www.asrock.com/mb/AMD/X670E Taichi/index.asp
KukKaBubBa
4
Hi, thanks a lot for your reply.
Asus TUF x670e had a lot of bios problems
probably it is the cause of the failure of my Ryzen 7700 (dead after a bios update)
Now if I enter the bios even if I do not change anything when I click on exit
the PC has a sort of Electric Bump and when it restarts gives an error on VGA
(and to start again I have to remove VGA, reset bios, put back vga and so on)
Morover I get a lot of core errors testing the pc with OCCT
so I think this mobo is bugged.
The Asrock mobo you linked me seems very nice but it costs more or less 550€
and I cannot afford it. 300€ is my top limit
You may want to look at same MB as mine . I'm very satisfied with it.
BIOS looks ugly but is very functional.
