Need help choosing between 2 Gaming PCs
Rasoulll
Hi, I am looking to buy a gaming pc, not because I game much, but because I have heavy use of multiple photo and video editing softwares at the same time and every laptop I buy heats up to a level that the charger port melts. For my budget I have found 2 amazing PCs but need help choosing the best option considering the fact that I am intending to use the PC for at least 3-4 years, that is upgrading the RAM and perhaps other hardware on it every now and then. Thanks
http://www.bestbuy.ca/en-CA/product/asus-asus-g10aj-gaming-pc-intel-core-i7-4790-2tb-hdd-16gb-ram-nvidia-gtx980-graphics-windows-8-1-g10aj-ca011s/10364438.aspx
http://pc.ncix.com/ncixpc_new/ncixpc.cfm?uuid=3BC5272E-61D9-441E-B9FC984873EF5F2D-6485891
My original thought was that since ASUS has the best motherboards around the ASUS G10AJ would be a more reliable computer than a custom PC built by people I do not know and people that might not have tested the computer to the best standards. Please let me know what you think!
the asus one is better it has a better gpu and a very good cpu and is cheaper and more powerful than the second option
although the second has a overclockable cpu but the performance will be the same so i rather opt for a better gpu
Thanks for your reply! Do you think it is an easy PC to upgrade as well or not?
