APPROXIMATE PURCHASE DATE: Next 30 days or so
CURRENT GPU AND POWER SUPPLY: GEforce Nividia GT 220 (happy with it but want to upgrade and its too noisy) Ocz 500w Modstream pro
OTHER RELEVANT SYSTEM SPECS: MoBo - Asus p8z68v le , CPU - undecided but likely i5 2500k (once on sale), Ram 1600 8 gig (2 sticks) not an issue can get more if needed for particular GPU
PARTS PREFERENCES: Open to either ati/Nividia but found Nividia more user friendly for me (novice computer geek)
OVERCLOCKING:No / MaybeSLI OR CROSSFIRE: No
MONITOR RESOLUTION: Using a 32" lcd tv
ADDITIONAL COMMENTS: Looking to spend up to $160 CDN (value is important), like cards with a vent. Minimal gaming, at most want SWTOR to run smooth.
Open to all opinions as I am new at this and been a while since I researched. Here are the ones I am looking at.
GIGABYTE GV-N460OC-1GI V3 GeForce GTX 460 (Fermi) 1GB 192-bit GDDR5 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125412
SPARKLE Calibre Series X550 Ti DFL GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814187149
(there are a ton of choices of 550's in my price range any manufacturers to stay away from?)
GIGABYTE Radeon HD 6850 1GB GDDR5 - http://www.memoryexpress.com/Products/MX35331
Thanks in advance.
Thanks in advance.
