need help choosing motherboard.
Dear,
Motherboard, which you have considered i.e Gigabyte Z97X SLI has following fan options:
1 CPU Fan Header
1 CPU_Opt Fan Header
3 System Fan Headers
You've 4 fans so utilizing 1 CPU_Opt fan header and 3 system fan headers you can mount your 4 fans on the mobo. Also, in case of more than 4 fans you can still mount them on the mobo using Y splittter cables (See the pic in previous post)
Check this mobo. It has 2 CPU fan headers and 3 system fan headers:
http://uk.pcpartpicker.com/part/msi-motherboard-z97g43gaming
Also this one has 1 CPU fan header and 3 system fan headers:
http://uk.pcpartpicker.com/part/gigabyte-motherboard-gaz97d3h
Also don't make fan headers as sole criteria. You can always molex your fans. Something like that:
Dear,
1 CPU Fan Header
