BigZero :
Thanks for ur reply, that is a nice build but I still have some questions if u dont mind.
Would an i7 4930k be a better choice compared to the E5 1650 v2? If going with Single CPU
Also I forgot to mention that HDD and SSD are not needed cuz I will be using my old ones.
Should I allocate more budget on CPU (possibly dual Xeon) or GPU (Quadro k5000)?
BigZero,
The applications you use > 3D modeling, animation, and rendering, are in the most demanding classification and would benefit from as many CPU and CUDA cores, as possible. As a system has to work in the most demanding application, I strongly recommend a Xeon, ECC RAM for those applications and a Quadro card to run the viewports in Maya and 3Ds Max- the demanding ones. In my view the Quadro K5000 is the ideal Maya card, and in fact is good at about everything.
The step up to a dual Xeon with an appropriate clock speed and Quadro K5000 is quite a jump in cost, but not inappropriately expensive given that you're running $20,000+ in software. Here is an idea of a good system of that kind that should have quite high performance >
BambiBoom PixelCannon Cadamodirendacompilarific ExtremeTurboSignature IWork 9000 ®©$$™®£™©™ _3.4.14
CPU > (2) Xeon E5-2643 V2 Six Core 3.5 / 3.8 GHz LGA2011 25MB > $3146 ($1578 ea)
____
http://www.provantage.com/intel-cm8063501287403~7ITEP3WR.htm
CPU OPT'L > (2) Intel Xeon Processor E5-2637 v2 Four core 3.5 / 3.8 GHz 15M Cache >$1992 ($996 each)
http://ark.intel.com/products/75792/Intel-Xeon-Processor-E5-2637-v2-15M-Cache-3_50-GHz
Motherboard > ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb/s USB 3.0 SSI EEB > $534
____
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131817
CPU Cooler > CORSAIR Hydro Series H60 (CW-9060007-WW) High Performance Water / Liquid CPU Cooler. 120mm > $130 ($65 ea)
____
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
RAM > 64GB (4) Kingston 1X16GB 240-Pin DDR3 SDRAM ECC Registered DDR3 1866 (PC3 14900) Server Memory Model KVR18R13D4/16 $745 ($185 ea) > VERIFY
___
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239756
GPU > NVIDIA Quadro K5000 4GB GDDR5 Graphics card > $1689.
____www.amazon.com/NVIDIA-Quadro-K5000-Graphics-PNY/dp/B009L8E4UO/ref=sr_1_1?ie=UTF8&qid=1391826733&sr=8-1&keywords=quadro+K5000
HD 1 > SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III TLC Internal Solid State Drive (SSD) > $400 (OS and Applications)
___
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147194
HD 2 and 3 > (2) Seagate Constellation ES.3 ST2000NM0033 2TB 7200 RPM 128MB Cache SATA 6.0Gb/s 3.5" Enterprise Internal Hard Drive Bare Drive > $ 294 ($197 ea) (RAID 1) (Files, system Image)
___
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178296
Power Supply > CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply > $160.
____http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Optical Drive > SAMSUNG DVD Burner 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM SATA Model SH-224DB/BEBE - OEM > $20
Case > Case Labs > Mercury S8 > with options $400
___ http://www.caselabs-store.com/mercury-s8/
OS > Microsoft Windows 7 Ultimate SP1 64-bit- OEM > $190
____
http://www.newegg.com/Product/Product.aspx?Item=N82E16832416808
__________________________________________________________
TOTAL = $7,708 or
$7,014 without SSD and HD's. With Xeon E5-2627 V2 and no drives =
$5,860
With 12 cores / 24 threads at high clock speeds, I believe this kind of system would be a far better performing and might extend the useful life up to three years longer than the single CPU concept. The only improvement to this system would be to have 2X 8-core Xeon 2768W V2 @ 3.5 /4GHz ($2,200 each).
If the budget is not as flexible, I believe the Quadro K5000 to be the best all round workstation card going and I for one would make an effort to have that one. When those are available used at under $800 (there have been a few sales close to that already), that will be my next GPU.
On the subject of used Quadros,, I might mention that I have had a used> FX550, FX570, FX580, FX1700, and FX4800 ($1,200 new, $150 to me when 18 months old) and I have never had one failure or problem that wasn't in reality a driver version problem. If you are good at judging used stuff and have patience, you might consider springing on a used Quadro K5000 deal. Here's one I missed by a day. > >
http://www.ebay.com/itm/Nvidia-Quadro-k5000-Brand-New-Taken-Out-Of-Packaging-For-Pictures-/171237369923?pt=PCC_Video_TV_Cards&hash=item27de8ae843
No guarantees of course, but my I can't believe that my luck with 5 used Quadros over 10 years is unique.
Cheers,
BambiBoom
