Hi,
I want to buy Dell T-7910 workstation & need technical help.
(1) I was using 3 ATI FirePro 2460 512 MB DDR3 low profile cards in my old Dell T-7500 workstation with 2 of them in PCIe Gen 2, 16x slots & one in a slot wired at speed of x8 with no problem. But new T-7910 has two PCIe Gen 3, 16x slots & one wired at speed of x4. So would speed of x4 work instead of old x8 & PCIe Gen 3 instead of PCIe Gen 2 ?
(2) I want to get an extra ATI FirePro 2460 512 MB as a back up but now new ones are ATI FirePro 2460 512 MB DDR5 instead of DDR3 & made by Sapphire. Would it be compatible with 2 old ones when all 3 are installed together ?
(3) For extra $50.00 I am getting ATI FirePro W4100 2 GB with new machine. Can I use it along with 2 old FirePro 2460 512 MB making a total of 3 GPUs ? How about drivers for them ?
(4) My old T-7500 which had Xeon E5645 2.4 GHz & worked great but for new T-7910 I am going for Xeon E5 2603 V3, 1.7 GHz for price reasons. Is that good enough ?
(5) My Old one had 12 GB DDR3 & never used more than 8 GB so for new one I am going for 8 GB DDR4 2133 MHz. Is that good enough ?
I would really appreciate any help.
Thank You
Thank You
