Need help computer is shutting down.
carlos00700700
5
Help abit AI7 sistem
Help.
A Bit AI7 set up is turning off when I play certain games...
p4 2.8
Corsair 2 512 kit 2.3.3.5
X800XL 256 AGP.
420 PSU
What games, at what times, more information. Questions cannot be answered without enough information, tell us all you know about the problem, computer.
Welcome, but you just need to be more clear.
Sorry,
Games like quake 3&4
Doom3 and half life2 are very stable...
Problem games.
PAIN KEEP
SSAMII
I upgraded windows xp to service pack three and updated all the abit chipset drivers, now I get a deep blue plain screen then I have to turn off.
Thanks
I upgraded windows xp to service pack three...
There is no such thing as a Service Pack 3 for Windows XP.
Beside, I don't think that anyone can troubleshoot your issues unless you feed us enough information to figure out what is happening.
Sorry,
Problem games.
PAIN KEEP
SSAMII
Thanks
I upgraded windows xp to the latest settings to date some one at work told me it was service pack three.
Its happened since I first build my system not sure why it does that but one time it said it was the software issue. Help what else do you need...
A DxDiag dump would be nice...
Start, Run, dxdiag (type dxdiag in the blank box and press Enter or click on the OK button)
Once the DirectX Diagnostic Tool is launched, click on the Display tab on top.
Click on the Test Direct Draw button, follow the instructions.
Click on the Test Direct 3D button, follow the instructions.
Once you're done, click on the Save All Informations... button found at the very bottom, you will be prompted to save a DxDiag.txt file, save it in an easely accessible location like your desktop.
Close DxDiag.
Locate the DxDiag.txt file, open it with a text editor like Notepad.
From the Edit menu found on top, click on Select All, the text will be highlighted.
Go to the Edit menu again, click on Copy.
When writing your next post, press and hold the Crtl button on your keyboard while pressing the V key, the text should be copied into your next post.
There is no such kill as overkill...
Close DxDiag.
O.K.
System Information
Time of this report: 3/13/2006, 17:30:37
Machine name: STEAM-H6XKA5VY7
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 277MB used, 2184MB available
Windows Dir: K:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: All tests were successful.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI RADEON X800 XL AGP (0x554D)
DAC type: Internal DAC(400MHz)
Device Key: EnumPCIVEN_1002&DEV_554D&SUBSYS_03021002&REV_00
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (150Hz)
Monitor: SONY GDM-F400/F400T9
Monitor Max Res: 1800,1440
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6587 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/4/2006 19:46:59, 252928 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 1/4/2006 19:46:40, 1420288 bytes
Device Identifier: {D7B71EE2-160D-11CF-096A-0823A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x554D
SubSys ID: 0x03021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB Audigy 2 ZS Audio [A000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_1102&DEV_0004&SUBSYS_20021102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0441 (English)
WHQL Logo'd: n/a
Date and Size: 10/7/2003 18:06:04, 366160 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: K:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy 2 ZS DirectMusic Synthesizer [A000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy 2 ZS Audio [A000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth A [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Sw Synth [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth B [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [A000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D2
| Matching Device ID: usbroot_hub
| Service: usbhub
| Driver: usbhub.sys, 1/15/2005 00:25:30, 57600 bytes
| Driver: usbd.sys, 8/29/2002 08:00:00, 4736 bytes
+-+ Logitech USB Wheel Mouse
| | Vendor/Product ID: 0x046D, 0xC00E
| | Matching Device ID: usbvid_046d&pid_c00e
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 19:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 19:08:18, 24960 bytes
| | Driver: hid.dll, 1/14/2005 21:47:11, 20992 bytes
| | Driver: hidusb.sys, 8/29/2002 08:00:00, 9600 bytes
| | | Matching Device ID: hidvid_046d&pid_c00e
| | | Service: mouhid
| | | Driver: mouclass.sys, 1/14/2005 21:47:11, 23040 bytes
| | | Driver: mouhid.sys, 1/14/2005 21:47:11, 12160 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x099A, 0x7150
| | Matching Device ID: usbclass_03&subclass_01
| | Service: HidUsb
| +-+ HID Keyboard Device
| | | Matching Device ID: hid_device_system_keyboard
| | | Service: kbdhid
| | | Driver: kbdhid.sys, 8/3/2004 18:58:36, 14848 bytes
| | | Driver: kbdclass.sys, 8/3/2004 18:58:34, 24576 bytes
Gameport Devices
+ Intel(R) 82801 PCI Bridge - 244E
| Matching Device ID: pciven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 1/15/2005 00:25:14, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pciven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 1/14/2005 21:47:11, 10624 bytes
PS/2 Devices
+ Terminal Server Keyboard Driver
| Matching Device ID: rootrdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 1/15/2005 00:25:26, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: rootrdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: All tests were successful.
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Network Bridge - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 57.4 GB
Total Space: 57.8 GB
File System: NTFS
Model: WDC WD1600JD-00HBB0
Drive: D:
Free Space: 46.1 GB
File System: NTFS
Drive: E:
Free Space: 14.5 GB
Total Space: 15.5 GB
File System: FAT32
Drive: K:
Free Space: 21.2 GB
Total Space: 35.3 GB
File System: NTFS
Model: WDC WD360GD-00FNA0
Drive: J:
Model: LITE-ON DVDRW SOHW-1633S
Driver: k:windowssystem32driverscdrom.sys, 5.01.2600.2180 (English), 8/3/2004 18:59:54, 49536 bytes
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Device ID: PCIVEN_8086&DEV_2571&SUBSYS_00000000&REV_023&13C0B0C5&0&08
Driver: K:WINDOWSsystem32DRIVERSAGP440.SYS, 5.01.2600.2180 (English), 1/15/2005 00:24:14, 42368 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCIVEN_8086&DEV_2570&SUBSYS_00000000&REV_023&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCIVEN_8086&DEV_24DE&SUBSYS_1028147B&REV_023&13C0B0C5&0&EB
Driver: K:WINDOWSsystem32driversusbuhci.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:30, 20480 bytes
Driver: K:WINDOWSsystem32driversusbport.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:30, 142976 bytes
Driver: K:WINDOWSsystem32usbui.dll, 5.01.2600.2180 (English), 1/15/2005 00:25:30, 74240 bytes
Driver: K:WINDOWSsystem32driversusbhub.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:30, 57600 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCIVEN_8086&DEV_24DD&SUBSYS_1028147B&REV_023&13C0B0C5&0&EF
Driver: K:WINDOWSsystem32driversusbehci.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:38, 26624 bytes
Driver: K:WINDOWSsystem32hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 20:56:44, 7168 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCIVEN_8086&DEV_24D7&SUBSYS_1028147B&REV_023&13C0B0C5&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCIVEN_8086&DEV_24D4&SUBSYS_1028147B&REV_023&13C0B0C5&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCIVEN_8086&DEV_24D3&SUBSYS_1028147B&REV_023&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCIVEN_8086&DEV_24D2&SUBSYS_1028147B&REV_023&13C0B0C5&0&E8
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCIVEN_8086&DEV_24D1&SUBSYS_1028147B&REV_023&13C0B0C5&0&FA
Driver: K:WINDOWSsystem32DRIVERSpciide.sys, 5.01.2600.0000 (English), 1/15/2005 00:25:14, 3328 bytes
Driver: K:WINDOWSsystem32DRIVERSpciidex.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:14, 25088 bytes
Driver: K:WINDOWSsystem32DRIVERSatapi.sys, 5.01.2600.2180 (English), 1/15/2005 00:24:16, 95360 bytes
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCIVEN_8086&DEV_24D0&SUBSYS_00000000&REV_023&13C0B0C5&0&F8
Driver: K:WINDOWSsystem32DRIVERSisapnp.sys, 5.01.2600.0000 (English), 1/15/2005 00:24:58, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCIVEN_8086&DEV_244E&SUBSYS_00000000&REV_C23&13C0B0C5&0&F0
Driver: K:WINDOWSsystem32DRIVERSpci.sys, 5.01.2600.2180 (English), 1/15/2005 00:25:14, 68224 bytes
Name: D-Link AirXpert DWL-AG520 Multimode Wireless PCI Adapter
Device ID: PCIVEN_168C&DEV_0013&SUBSYS_3A081186&REV_014&1F7DBC9F&0&20F0
Driver: K:WINDOWSsystem32DRIVERSA3AB.sys, 2.03.0001.0011 (English), 4/3/2003 12:13:00, 307744 bytes
Driver: K:WINDOWSsystem32DWLInst.dll, 1.00.0001.21216 (English), 4/3/2003 12:13:00, 24576 bytes
Name: Creative Game Port
Device ID: PCIVEN_1102&DEV_7003&SUBSYS_00401102&REV_044&1F7DBC9F&0&31F0
Driver: K:WINDOWSsystem32driversgameenum.sys, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 10624 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCIVEN_1102&DEV_4001&SUBSYS_00101102&REV_044&1F7DBC9F&0&32F0
Driver: K:WINDOWSsystem32DRIVERSohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 19:10:10, 61056 bytes
Driver: K:WINDOWSsystem32DRIVERS1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 19:10:08, 53248 bytes
Driver: K:WINDOWSsystem32DRIVERSnic1394.sys, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 61824 bytes
Driver: K:WINDOWSsystem32DRIVERSarp1394.sys, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 60800 bytes
Driver: K:WINDOWSsystem32DRIVERSenum1394.sys, 5.01.2600.0000 (English), 8/17/2001 05:46:40, 6400 bytes
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCIVEN_1102&DEV_0004&SUBSYS_20021102&REV_044&1F7DBC9F&0&30F0
Driver: K:WINDOWSsystem32ksuser.dll, 5.03.2600.2180 (English), 1/15/2005 00:24:58, 4096 bytes
Driver: K:WINDOWSsystem32ksproxy.ax, 5.03.2600.2180 (English), 1/15/2005 00:24:58, 130048 bytes
Driver: K:WINDOWSsystem32driversks.sys, 5.03.2600.2180 (English), 1/15/2005 00:24:58, 140928 bytes
Driver: K:WINDOWSsystem32driversdrmk.sys, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 60288 bytes
Driver: K:WINDOWSsystem32driversportcls.sys, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 145792 bytes
Driver: K:WINDOWSsystem32driversstream.sys, 5.03.2600.2180 (English), 1/14/2005 21:47:11, 48640 bytes
Driver: K:WINDOWSsystem32wdmaud.drv, 5.01.2600.2180 (English), 1/14/2005 21:47:11, 23552 bytes
Driver: K:WINDOWSsystem32driversctac32k.sys, 5.12.0001.0442 (English), 10/21/2003 01:22:18, 645360 bytes
Driver: K:WINDOWSsystem32driversctaud2k.sys, 5.12.0001.0441 (English), 10/7/2003 18:06:04, 366160 bytes
Driver: K:WINDOWSsystem32driversctoss2k.sys, 5.12.0001.0441 (English), 10/7/2003 18:06:50, 178672 bytes
Driver: K:WINDOWSsystem32driversctprxy2k.sys, 5.12.0001.0441 (English), 10/7/2003 18:08:12, 6096 bytes
Driver: K:WINDOWSsystem32driversctsfm2k.sys, 5.12.0001.0441 (English), 10/7/2003 18:09:10, 130288 bytes
Driver: K:WINDOWSsystem32driversemupia2k.sys, 5.12.0001.0442 (English), 10/13/2003 01:42:12, 145488 bytes
Driver: K:WINDOWSsystem32driversha10kx2k.sys, 5.12.0001.0444 (English), 10/21/2003 01:26:08, 904496 bytes
Driver: K:WINDOWSsystem32drivershaP16v2k.sys, 5.12.0001.0442 (English), 10/21/2003 01:23:44, 148432 bytes
Driver: K:WINDOWSsystem32driverspfmodnt.sys, 3.00.0000.0003 (English), 3/5/2003 12:19:28, 15840 bytes
Driver: K:WINDOWSsystem32ctdlang.dat, 10/21/2003 01:54:50, 217272 bytes
Driver: K:WINDOWSsystem32ctstatic.dat, 10/21/2003 01:47:40, 298971 bytes
Driver: K:WINDOWSsystem32ctdaught.dat, 10/21/2003 01:47:34, 53932 bytes
Driver: K:WINDOWSsystem32commonfx.dll, 5.12.0001.0440 (English), 10/5/2003 22:44:28, 114688 bytes
Driver: K:WINDOWSsystem32ctaudfx.dll, 5.12.0001.0440 (English), 10/5/2003 22:44:58, 581632 bytes
Driver: K:WINDOWSsystem32ctsblfx.dll, 5.12.0001.0440 (English), 10/5/2003 22:46:14, 606208 bytes
Driver: K:WINDOWSsystem32ctbas2w.dat, 10/21/2003 01:54:48, 140643 bytes
Driver: K:WINDOWSsystem32ctsbas2w.dat, 10/21/2003 01:54:42, 264466 bytes
Driver: K:WINDOWSsystem32SBAudigy.ico, 8/16/2001 20:42:28, 7406 bytes
Driver: K:WINDOWSsystem32Audigy.bmp, 11/12/2001 17:48:20, 1912 bytes
Driver: K:WINDOWSsystem32ctcoinst.dll, 3.00.0000.0004 (English), 10/5/2003 22:48:30, 69632 bytes
Driver: K:WINDOWSsystem32ctdvinst.dll, 1.82.0000.0001 (English), 6/27/2003 01:51:42, 122880 bytes
Driver: K:WINDOWSsystem32driversctdvda2k.sys, 5.13.0001.0413 (English), 10/13/2003 19:17:56, 332800 bytes
Driver: K:WINDOWSsystem32a3d.dll, 80.00.0000.0003 (English), 6/19/2003 19:28:18, 65536 bytes
Driver: K:WINDOWSsystem32sfman32.dll, 5.12.0001.0130 (English), 8/16/2001 22:35:46, 36864 bytes
Name: RADEON X800 Series - Secondary
Device ID: PCIVEN_1002&DEV_556D&SUBSYS_03031002&REV_004&299CCBFA&0&0108
Driver: K:WINDOWSsystem32DRIVERSati2mtag.sys, 6.14.0010.6587 (English), 1/4/2006 19:46:40, 1420288 bytes
Driver: K:WINDOWSsystem32DRIVERSati2erec.dll, 1.00.0000.0005 (English), 1/4/2006 19:10:15, 40960 bytes
Driver: K:WINDOWSsystem32DRIVERSativvpxx.vp, 1/4/2006 21:04:25, 25552 bytes
Driver: K:WINDOWSsystem32DRIVERSativckxx.vp, 6/8/2005 11:45:54, 58560 bytes
Driver: K:WINDOWSsystem32DRIVERSativcaxx.vp, 10/12/2005 09:05:09, 929 bytes
Driver: K:WINDOWSsystem32DRIVERSativcaxx.cpa, 10/12/2005 09:05:09, 1114674 bytes
Driver: K:WINDOWSsystem32ati2dvag.dll, 6.14.0010.6587 (English), 1/4/2006 19:46:59, 252928 bytes
Driver: K:WINDOWSsystem32ati2cqag.dll, 6.14.0010.0303 (English), 1/4/2006 19:05:36, 237568 bytes
Driver: K:WINDOWSsystem32Ati2mdxx.exe, 6.14.0010.2495 (English), 1/4/2006 19:41:18, 26112 bytes
Driver: K:WINDOWSsystem32ati3duag.dll, 6.14.0010.0362 (English), 1/4/2006 19:31:28, 2518176 bytes
Driver: K:WINDOWSsystem32ativvaxx.dll, 6.14.0001.0079 (English), 1/4/2006 19:25:12, 862336 bytes
Driver: K:WINDOWSsystem32atiicdxx.dat, 12/22/2005 14:44:29, 112425 bytes
Driver: K:WINDOWSsystem32ATIDDC.DLL, 6.14.0010.0007 (English), 1/4/2006 19:39:21, 53248 bytes
Driver: K:WINDOWSsystem32atitvo32.dll, 6.14.0010.4200 (English), 1/4/2006 19:10:58, 17408 bytes
Driver: K:WINDOWSsystem32ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 08:01:04, 24064 bytes
Driver: K:WINDOWSsystem32ati2evxx.exe, 6.14.0010.4124 (English), 1/4/2006 19:39:46, 405504 bytes
Driver: K:WINDOWSsystem32ati2evxx.dll, 6.14.0010.4124 (English), 1/4/2006 19:40:59, 61440 bytes
Driver: K:WINDOWSsystem32atipdlxx.dll, 6.14.0010.2495 (English), 1/4/2006 19:41:42, 110592 bytes
Driver: K:WINDOWSsystem32Oemdspif.dll, 6.14.0001.0014 (English), 1/4/2006 19:41:25, 77824 bytes
Driver: K:WINDOWSsystem32ati2edxx.dll, 6.14.0010.2499 (English), 1/4/2006 19:41:11, 40960 bytes
Driver: K:WINDOWSsystem32atikvmag.dll, 6.14.0010.0030 (English), 1/4/2006 19:11:38, 151552 bytes
Driver: K:WINDOWSsystem32ATIDEMGR.dll, 1.02.2195.38461 (English), 1/4/2006 18:22:03, 258048 bytes
Driver: K:WINDOWSsystem32atifglpf.xml, 11/28/2005 07:43:39, 6024 bytes
Driver: K:WINDOWSsystem32atioglxx.dll, 6.14.0010.5529 (English), 1/4/2006 19:01:34, 4968448 bytes
Driver: K:WINDOWSsystem32atioglx1.dll, 6.14.0010.1030 (English), 1/4/2006 19:20:05, 6684672 bytes
Driver: K:WINDOWSsystem32atiiiexx.dll, 6.14.0010.4004 (English), 1/4/2006 19:19:00, 307200 bytes
Device ID: PCIVEN_1002&DEV_554D&SUBSYS_03021002&REV_004&299CCBFA&0&0008
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/29/2002 08:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/29/2002 08:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/29/2002 08:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/29/2002 08:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 1/14/2005 21:47:11 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 82432 bytes
system.dll: 1.01.4322.0573 English Final Retail 1/1/2003 03:37:09 1216512 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/29/2002 08:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 20:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 20:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/3/2004 20:56:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/3/2004 20:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:26 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 19:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/3/2004 20:56:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 20:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 20:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 20:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 20:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 20:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 20:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 20:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 20:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:46 204288 bytes
msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 74240 bytes
ks.sys: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 1/14/2005 21:47:11 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 4352 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 1/14/2005 21:47:11 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 1/14/2005 21:47:11 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 1/14/2005 21:47:11 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 1/14/2005 21:47:11 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 19:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 20:56:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 19:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 1/15/2005 00:25:06 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:20 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 1/15/2005 00:25:06 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 1/15/2005 00:24:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 1/15/2005 00:25:32 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 1/15/2005 00:25:32 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 20:56:48 50688 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
ATI Specialized MVD Codec,0x00200000,1,0,,5.03.2600.2180
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.00.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0007
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,2.00.0001.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0007
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.01.0001.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0003.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.2107
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.1027
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.0917
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
ATI Time Shift Splitter,0x00600000,1,2,atidvcr.dll,9.03.0000.41201
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,9.03.0000.41201
ATI Time Shift Writer,0x00200000,1,0,atidvcr.dll,9.03.0000.41201
ATI Time Shift Receiver,0x00200000,0,1,atidvcr.dll,9.03.0000.41201
ATI MPEG Video Decoder,0x00600000,1,2,atidvcr.dll,9.03.0000.41201
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
ATI Teletext Renderer,0x00200000,1,0,atittext.ax,9.03.0000.0002
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0007
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
ATI Video Capture Surface Allocator,0x003fffff,1,0,ativvpxx.ax,4.13.0001.5085
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0007
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0007
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0007
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0007
Nero Digital AVC Video Enc,0x00200000,1,2,,
ATI VCR Video Converter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0007
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0007
ATI VBI Surface Allocator,0x00200000,1,0,AVBISurf.ax,9.03.0000.0001
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0007
ATI Line21 CC Decoder/Renderer,0x00200000,1,0,ATICCap.ax,9.03.0000.0001
CyberLink Demux (PDVD6),0x00200000,1,0,CLDemuxer.ax,1.00.0000.2221
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,5.00.0000.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0007
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
CyberLink Video/SP Decoder (ATI),0x00600000,2,3,CLVSD.ax,6.00.0000.0716
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0007
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0000.0000
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
ATI Time Shift Copier,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0007
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,2.00.0002.0000
ATI CC Multiplexer,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ATI MPEG Audio Encoder,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
ATI VCR Stream Sink,0x00200000,0,0,atidvcr.dll,9.03.0000.41201
ATI Teletext Provider,0x00600000,1,0,ativtpxx.ax,9.03.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0007
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
ATI MPEG Video Encoder,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0007
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0007
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.01.0000.0000
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0007
ATI MPEG Multiplexer,0x00200000,2,1,atidvcr.dll,9.03.0000.41201
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0007
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.02.0001.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0007
ATI Teletext to CC Converter,0x00200000,1,2,atitt2cc.ax,9.03.0000.0001
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,6.00.0000.1006
ATI Video Scaler Filter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0007
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.1015
ATI Closed Caption Database,0x00200000,1,0,aticcdb.ax,9.03.0000.0006
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1102
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0007
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0007
ATI Still Capture Filter,0x00200000,1,0,atidvcr.dll,9.03.0000.41201
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0000.0002
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
CyberLink DVD Navigator (ATI),0x00600000,0,3,CLNavX.ax,5.00.0000.1923
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0007
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0007
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,2.00.0004.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.2180
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,2.00.0002.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0007
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1010
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0007
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0007
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0007
NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0007
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0007
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,2.00.0002.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0007
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0007
ATI VCR Stream Source,0x00600000,0,0,atidvcr.dll,9.03.0000.41201
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
CyberLink Audio Decoder (ATI),0x00601000,1,1,claud.ax,6.00.0000.0726
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0007
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
ATI FM-On-Demand Filter,0x00200000,1,1,atidvcr.dll,9.03.0000.41201
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0007
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
ATI YUV12 Format Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy 2 ZS Audio [A000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS MIDI IO [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Sw Synth [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth A [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth B [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
ATI Rage Theater Video Capture,0x00200000,2,4,,5.03.2600.2180
SB Audigy 2 ZS MIDI IO [A000],0x00200000,2,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [A000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 ZS DirectMusic Synthesizer [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Sw Synth [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth A [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth B [A000],0x00200000,1,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.2180
WDM Streaming Crossbar Devices:
ATI Rage Theater Video Crossbar,0x00200000,3,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
SB Audigy 2 ZS Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Renderer (PDVD6),0x00200000,1,0,CLADR.ax,6.00.0000.1011
CyberLink Audio Renderer (ATI),0x00200000,1,0,CLADR.ax,6.00.0000.0720
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy 2 ZS Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB Audigy 2 ZS Synth A [A000],0x00200000,11,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [A000],0x00200000,13,2,,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
First off, it seems like Pain Keep is a freeware add-on to the obsolete Quake 2 game, that could make it prone to fail when running on new hardware with recent drivers.
As for Serious Sam II, it seems that there are some patches out, you may want to try those.
If it fail to help, take some time to do a clean OS install on your C: drive, this will eliminate any software issues and further problems will most likely point toward a possible hardware failure.
Otherwise, I don't think that you will be able to pinpoint any specific cause to the problems that you are experiencing.
As for the heat and CPU, all of his games would be affected, not two out of the bunch...
The software is the prime suspect IMHO, once it is ruled out with a new OS install, thermal and voltage monitoring is an easy thing to do.
Pointing fingers at hardware won't do any good at this point, an overheating CPU or a substandard PSU would show sign of failure when running any recent games, not in a couple out of the bunch.
Well, the DxDiag dump is usefull for first line troubleshooting but it tend to be overkill, especially when you consider that most of its content is useless crud that all the readers will have to scroll through.
Still, it is invaluable when you need to rule out driver level issues and get a good feel of someone's hardware, especially when that person seems to be unable to communicate that information.
