Hello all, I have been having problems for about 2 months, here's a little back round of what led up to this. I was having problems with Diablo 3 freezing up while playing Season 15. At first I thought it was the game, it would freeze up while doing Greater Rifts, then it started doing it playing anything in the game. (I have a evga 1080TI, so i had everything maxed out and it played fine until about last week of September.) I tried turning down all the graphics settings to the lowest settings, I tried full-screen windowed mode, the issue was still happening. I then uninstalled the graphics drivers and re-installed the latest drivers for the card--- same issue. I then tried other games, (Witcher 3 and Shadow of War) same thing would happen, game would freeze a couple of minutes in and I could not escape or even get to the task manager... I had to turn the computer completely off and restart. I then thought it might have been a windows issues since we got an update @ September 28th so I rolled back the update and still no change. So then I tried uninstalling and re-installing the games, same issue. I ran a virus scan, no change, I wiped my drives clean and did a fresh install, same issue. The computer was overclocked so I then tried to reset the bios using "optimized default" settings but it would not boot from the optimized settings. I reset the cmos (removed the battery for about 2 min and reseated), but It still would not load to windows on default settings.. So I went back and loaded up the overclock profile to which the computer would load to Windows, but it still did not solve the problem of games crashing nor allow me to load "optimized defaults". I downloaded the current bios for my motherboard and flashed it but in doing so, it wiped my overclock profile and now it won't load to windows at all. I need help, this is my gaming as well as my business computer. Thank you in advance.
Here's my system specs:
Intel I5_4670K
Asus ROG Maxiumus Hero VI
Samsung 840pro x 2 Raid0
G-Skill 2400 (Trident) X 8G x 2
Windows 10 Home 64bit
Thermaltake 850 PSU
EVGA 1080TI
Corsair h 100i cooler
Intel I5_4670K
Thermaltake 850 PSU
EVGA 1080TI
