Build Advice Need help deciding my next pc case...
James9002uk
Commendable
May 30, 2017
42
I have the following PC spec which I need to consider:
ATX motherboard,
i7 9700k with Corsair h100v2 240mm rad,
1x 1TB HHD,
2x SSD,
RTX EVGA 2070 with AIO 120mm 270mm long
Now I'm thinking of the following four cases:
  • Lian Li PC-O11AIR
  • Fractal Design Define R6
  • PHANTEKS Eclipse P600S
  • Corsair Obsidian 500D
Of course I've already done my own research on YouTube from the known reviewers but I was wondering if anyone else has moved to either of the above cases and liked/disliked their experience... As I'm really torn between them all...
I'd like the option to maybe go water cooling down the line so needs to be an option for that, I also like the idea of the two compartments that the O11 gives... I'd like the option to maybe mount the GPU vertical as well.
Getting the best possible airflow is important (as the 9700k and RTX 2070 do run hot) and also acoustics, obviously there are trade offs for all and I'm never going to find one for all of the above.
Any thoughts or advice or any other case would be great, thanks!
