[SOLVED] Need help deciding on which gpu i should pick
Bloushi
15
Hello everyone i have a some questions about then next gpu i should buy and if its compatible with my rig.
I'm deciding if i should go with this gpu (ASUS ROG Strix RTX 2060 Super OC ) or if i should save up more money and buy this gpu (ASUS ROG Strix RTX 2070 Super OC).
1-Is it worth it for me if i go for the 2070 super one and wait some more time.
2-is the (ASUS ROG Strix RTX 2070 Super OC) compatible with my rig (like is it compatible with my psu's power cables and will my psu supply enough power for my setup with the gpu and be compatible with the my motherboard and the rest of my setup) .
My Setup:
CPU: i7-8700
Motherboard :z370 gaming plus
Ram:16 GB
Storage: 1TB HHD
PSU: Cooler Master MasterWatt Lite 700 Watt PSU
Current GPU : ASUS 4gb GTX 1050Ti Strix OC Edition
Case: Phantom 410 white
OS: Windows 10
Thanks a lot for the help.
