Need help deciding
iblessi
13
PLEASE DONT TRY TO CONVINCE TO BUILD MY OWN
I can't decide if I should get the ibuypower with the rx480 8gb or the cyber power with the rx480 4gb. I want a pc That I can upgrade the cpu and gpu and I can't decide (price Dosnt matter) https://www.amazon.com/gp/aw/reviews/B01HNBLHAA/ref=cm_cr_getr_mb_paging_btm_3?ie=UTF8&s=sd&sortBy=sd&pageNumber=3 And this https://www.amazon.com/gp/aw/d/B01HIS315C/ref=mp_s_a_1_2?ie=UTF8&qid=1479946277&sr=8-2&pi=SY200_QL40&keywords=rx+480+i5&dpPl=1&dpID=51qCkf%2BKiLL&ref=plSrch
I said in that comment to get the IBP one....
It's actually pretty good value for a prebuilt.
Both of them have a socket LGA 1151 motherboard which means you can upgrade them to an i7 6700k when the time comes, and the GPU can be easily upgraded as well. I would just go for the 8gb RX 480 so that in the future you won't have problems with too little video memory.
You cannot crossfire or SLI a second GPU because of their motherboards, which are B150's, and only support one PCI x16. Size-wise, it all depends on the size of the GPU that you plan to swap with.
Tower size has no effect on the GPU but if the motherboard only supports 1 GPU then you won't be able to run a second GPU. Someone also notes that the PSU is only 600W which in most cases is too low (probably a low quality unit as well) to run a second GPU. Anyways your always better off getting the best single GPU you can afford.
You can get parts and send them to a store for assembly to get significantly better value, is that something you'd be interested in?
