skit75 :
You should be able to change your RAM clock in the BIOS Setup.... unless your motherboard has it locked(shaded out). Best to just post your info in a wall o' text here and if someone feels froggy enough to read all of it, maybe be able to offer some advice.
Ok, thanks. I actually changed it in BIOS and then decided not to save it just in case it could be detrimental as I wasn't sure if forcing it to 1600 was safe or not. Thanks for the info, I'll adjust that.
I'll post the log. Thanks for the help!
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.3.0
Monitoring
Mainboard Model TA970 (0x00000135 - 0x0002E480)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x0
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 00 00 00 01 80 00 81 00 00 40 06 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 00 0A 20 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A00
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.34 Volts [0x70] (CPU VCORE)
Voltage 1 1.55 Volts [0x81] (VIN1)
Voltage 2 2.86 Volts [0xEE] (+3.3V)
Voltage 3 4.70 Volts [0xE9] (+5V)
Voltage 4 4.80 Volts [0x64] (+12V)
Voltage 5 -4.80 Volts [0x64] (-12V)
Voltage 6 -4.46 Volts [0x5D] (-5V)
Voltage 7 2.80 Volts [0x8B] (+5V VCCH)
Voltage 8 1.74 Volts [0x91] (VBAT)
Temperature 0 38°C (100°F) [0x26] (TMPIN0)
Temperature 1 29°C (84°F) [0x1D] (TMPIN1)
Temperature 2 49°C (120°F) [0x31] (TMPIN2)
Fan 0 2280 RPM [0x128] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 13 16 00 00 FF FF FA FF FF FF 48 0F 87 28 FF FF
10 48 00 09 77 C7 80 00 00 01 FF FF F1 04 96 96 96
20 70 81 EE E9 64 64 5D 8B 91 26 1D 31 80 3F F0 F0
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 4B 7F 7F 7F 55 50 5F 40 AD 6A D4 00 FF FF FF FF
50 FF 23 7F 7F 7F 40 FA 00 90 00 3E 12 60 00 00 00
60 0A 14 46 38 23 02 00 FF 7F 7F 7F FF 00 02 00 FF
70 7F 7F 7F FF 00 02 00 FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 1E C2 C8
90 FF 00 00 00 FF 00 00 00 42 99 00 00 01 1C 52 2C
A0 A1 A2 A2 A2 A2 A2 A2 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 38°C (100°F) [0xC28] (THRM)
Hardware monitor AMD ADL
Voltage 0 0.82 Volts [0x339] (VIN0)
Temperature 0 32°C (89°F) [0x20] (TMPIN0)
Processors
Number of processors 1
Number of threads 6
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
-- Core 4
-- Thread 0 4
-- Core 5
-- Thread 0 5
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.418 MHz
Sys timer 1.000 KHz
BCLK timer 199.99 MHz
Processors Information
Processor 1 ID = 0
Number of cores 6 (max 6)
Number of threads 6 (max 6)
Name AMD FX-6300
Codename Vishera
Specification AMD FX(tm)-6300 Six-Core Processor
Package Socket AM3+ (942)
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
TDP Limit 94 Watts
Core Speed 3800.0 MHz
Multiplier x Bus Speed 19.0 x 200.0 MHz
Rated Bus speed 2400.0 MHz
Stock frequency 3500 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
L1 Data cache 6 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 3 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 3 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x19 - VID 0x0A - IDD 17 (20.50x - 1.425 V)
P-State FID 0x16 - VID 0x0F - IDD 17 (19.00x - 1.362 V)
P-State FID 0x13 - VID 0x18 - IDD 12 (17.50x - 1.250 V)
P-State FID 0xE - VID 0x1F - IDD 9 (15.00x - 1.162 V)
P-State FID 0x9 - VID 0x27 - IDD 7 (12.50x - 1.063 V)
P-State FID 0x4 - VID 0x2E - IDD 6 (10.00x - 0.975 V)
P-State FID 0x10C - VID 0x38 - IDD 4 (7.00x - 0.850 V)
PStateReg 0x800001A8-0x00001419
PStateReg 0x800001A8-0x00001E16
PStateReg 0x80000174-0x00003013
PStateReg 0x8000015E-0x00003E0E
PStateReg 0x8000014A-0x00004E09
PStateReg 0x80000138-0x00005C04
PStateReg 0x80000125-0x0000704C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 13 Watts
Boosted P-States 2
Max non-turbo ratio 17.50x
Max turbo ratio 20.50x
TSC 3500.2 MHz
APERF 3799.9 MHz
MPERF 3500.0 MHz
Attached device PCI device at bus 0, device 24, function 0
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 000000C1 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00073900 00000000 00000000 00000000
160 00000000 00000000 00000400 0066E066
170 00000109 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 80000003 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 0000003E
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
120 00000000 00000045 00000000 00000000
130 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00003E51 00000000 00000000
110 00000500 00000000 0440A424 0CE00F41
120 00EBFF0D 00000000 00000000 00000000
130 EABE17F1 E38FE782 E5E2E780 F0DF0342
140 00000001 00000109 00000000 00000000
160 01F83EE0 00000000 00000000 00000000
170 00000000 00000000 00020000 18240028
180 0000000A 00800004 3C000000 00020000
190 0B010000 0F48088E 8D0F4007 00000000
1A0 031D0200 00000000 00000000 00000000
1B0 0FC39001 480F7D05 00000000 00000000
Attached device PCI device at bus 0, device 24, function 3
140 00A11755 00000055 0000C12A 00000000
160 C00A0FFF 00000000 C00A0FFF 00000000
170 C00A0FFF 00000000 00000000 00000009
180 017003E3 00000000 08000210 00000000
190 00000000 00000000 00780400 00000000
1A0 00034144 00000000 00000000 00000000
1B0 210FAD04 00000000 00141000 00000000
1C0 00000000 0003CCCC 00000000 00000100
1D0 00000000 00000000 002B170F 00000000
1E0 00000000 80001387 00000000 00000000
1F0 00080000 00000000 00000000 004C074F
Attached device PCI device at bus 0, device 24, function 4
100 00000000 00000321 00000000 0085014C
110 000FE001 00000000 0007000B 00000000
120 00000000 00000000 00000500 00000000
140 1159C931 0000034D 23A2DC39 0000079D
150 00000B68 00B4B490 00000000 00000089
160 00600F20 00000003 00000000 00000257
180 E000530F 00001004 00000000 00000000
1A0 00000000 0A47B081 00000000 00000000
1B0 C3B56C81 C3B56C81 00350182 00000000
1C0 00000117 00000110 00002BC0 00000090
1D0 00080000 0000FFFF 00000000 00000000
1E0 0B501419 0B501E16 0AE83013 0ABC3E0E
1F0 0A944E09 0A705C04 0A4A704C 00000000
Attached device PCI device at bus 0, device 24, function 5
120 00001111 80000000 00009138 00000000
160 0000780D 00000000 00000000 00000000
170 00000608 0001E030 00000000 00000000
190 2233457A 0000000B 00202020 00000000
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02040008h
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 6 thread(s)
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F20 0x00060800 0x3E98320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000008 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F20 0x10000000 0x01EBBFFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x362D296D 0x20303033
0x80000003 0x2D786953 0x65726F43 0x6F725020 0x73736563
0x80000004 0x2020726F 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140
0x80000006 0x64006400 0x64004200 0x08008140 0x0040C140
0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9
0x80000008 0x00003030 0x00000000 0x00004005 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x00014163 0x0FC0003F 0x000007FF 0x00000001
0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000040
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x800001A8 0x00001419
MSR 0xC0010065 0x800001A8 0x00001E16
MSR 0xC0010066 0x80000174 0x00003013
MSR 0xC0010067 0x8000015E 0x00003E0E
MSR 0xC0010068 0x8000014A 0x00004E09
MSR 0xC0010015 0x00000000 0x09000011
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010058 0x00000000 0xF0000019
MSR 0xC0010071 0x01000006 0x3C011E16
MSR 0xC0010070 0x00000000 0x3C011E16
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x01060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x02060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x03060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x04060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000014 0x00000102 0x00000000 0x00000000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 5, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x05060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000015 0x00000102 0x00000000 0x00000000
