[SOLVED] Need Help! Dell 7920T w/ 80G5N Quad Ultra-Speed PCI Adapter
Dec 11, 2019
Need some help with this one...
I bought a "good/tested" used 80G5N Adapter for my Dell Precision 7920T which should be compatible. I installed x4 970 Evo Plus 500gb NVME members.
My system will only detect the NVME that is plugged into the first slot of the 80G5N. The other 3 are not detected at all.
Dell tech deperartment says the 80G5N is DOA. So I purchased another one. Brand New this time....same results unfortunately.
Dell Tech dept. is now suggesting both 80G5N cards are DOA. I find that extremely hard to believe...
Everything I can find leads me to believe this setup should be plug and play.
Any suggestions?
Does your bios also only detects 1 drive?
Try swapping the drives.
If not get a replacement.
The first slot of the interposer is detected. If I put a single nvme in the 2nd, 3rd, 4th slot....it will not be detected.
I agree...buy a new card. Except I just did that...I bought a new card and have the same problem. Its definitely not impossible, but extremely unlikely that both cards arrived DOA.
