PC: HP P7 1120
Mobo: carmel 2 (intel)
Cpu: i3 2130 3.4 ghz
PSU: 500w 80+ cert (upgraded)
Windows 10
I tried installing 2 different GPUs: Sapphire R9 270 and RX 560, the system doesn't recognize either card although the fans spin.
The bios seems to be legacy only although there is an option to "run uefi application" (but this does nothing when selected). I go to run>Msinfo32 on and it shows legacy mode for the mobo.
The options I came up with are:
I am considering purchasing a second hand dell pc that I believe has a uefi mobo, the inspiron 660 ,that has an i3 2nd or 3rd gen, but I actually like the HP case, will I run into any compatibility issues dropping in that dell board into the HP case? The HP has the multi card reader and built in wifi, sound usb in the front.
Or should I just buy an old gtx 660 maybe? And sell off the GPUs I have now. What would you do and why?
Windows 10
- Get a legacy enabled GPU like a gtx 600 series or hd7000 series.
- Swap the motherboard for a uefi enabled one.
