I recently bought a benq xl2420tx monitor. After first plugging it up it worked well and all I had to do was set the resolution to what I wanted. I used the Nvidia control panel and everything was fine. I even tried the 3d setup and tested a few games. Nothing was wrong. When I played cod black ops 2 the color inverted a few times and as I loaded the career the game would freeze during the video clip and restart my computer. I got frustrated and went on to play counter strike go which was quite fun but my crosshair wouldn't line up in 3d.
Well, since I hadn't been on my computer in almost a month there were a few updates I needed. Such as steam and uplay. And I think also had an Nvidia update I'm not quite sure. Anyway, I shut down the computer and later that day I came back to show my girlfriend how cool the 3d looked.
When I turned my computer on it was like all my settings were gone. The actual view of the screen was about 20% of the surface of the monitor. It wasnt the same as I left it. I tried multiple times to open Nvidia control panel to fix it but all I got was this message: "you are not currently using a display attached to an Nvidia gpu"
I had the monitor plugged up using a monster 1000hd hdmi cable. I've tried hdmi and div inputs but neither are working. I've tried downloading new drivers and even restoring my computer to an earlier date but I can't figure it out.
-and yes i DID have it plugged to the graphics card and not the motherboard.
PLEASE HELP
Manufacturer: cyberpowerpc
Windows 8 64-bit
Intel core I7-3770k
2x8gb ram (16gb)
Nvidia GeForce 660 ti
also i went to control panel > device manager and under display adapters i saw my video card. i viewed the properties of it and there was this error message: Windows has stopped this device because it has reported problems. (Code 43)
-someone from cyberpowerpc told me to try and reseat the gpu and check connections and i did. that did not help
-i used driver fusion to clean all files left behind after i uninstalled and when i reinstalled new drivers i got the same error
PLEASE HELP
Windows 8 64-bit
Intel core I7-3770k
2x8gb ram (16gb)
