Hi, I'm hoping someone might have a similar situation and/or know what the best approach might be. We've got a 3 story townhouse, and I will try to describe the layout of everything and what the issues are.
Third floor: Primary desktop computer, cable modem, wireless router 👎, TV. Printer theoretically networked.
Second floor: secondary desktop connected to wireless (VG to excellent signal strength, no noticeable delays), TV with DVR connected via coax; Bluray connected via HDMI, Roku connected via HDMI, connected to wireless network. Signal G-VG but there is lag in streaming netflix). Laptop used here, connected to wifi, signal VG
First floor: Primary TV connected by cable box. HDMI to Blu Ray player (only has ethernet port). Laptop frequently used here but signal strength is awful. It's always low, and often vanishes entirely. Maddeningly slow, so even if the Bluray had wifi, it wouldn't work well, certainly not HD streaming.
Goals:
1. Improve wireless signal coverage on 1st floor
2. Connect Blu Ray player to internet. There is a part available to add wireless, but my research shows that it is extremely expensive and those who have ordered it haven't had any luck getting it to work. If we can't find a way to establish an ethernet connection downstairs (like via powerlines) we may just get a new Bluray that has wifi, or swap with the one on the 2nd floor that has wifi, since it's not being used (the Roku does everything the player does, plus some apps it can't)
3. Avoid the following to the greatest extent possible: death, divorce, disowning of children such as myself, marathon calls or chats with tech support in India, drilling of walls, running hardwired cables throughout the house...
Issues:
No one tremendously tech savvy here. I'm not totally tech illiterate, but networking is not my strong suit. Would be major objection to messing with the third floor router and modem setup--plus that computer is the primary one so needs to be a wired connection.
Thanks in advance for any thoughts or suggestions!
Goals:
Issues:
