[SOLVED] Need Help Figuring Out What To Upgrade
Aug 3, 2019
Got this computer about 2 years ago and because new games are coming out (specifically games like the new modern warfare) I feel like I might need to upgrade soon. I'm not too tech savvy so I don't know what exactly to upgrade or if I need an upgrade at all.
Specs and UserBenchmark Results:
UserBenchmarks: Game 58%, Desk 45%, Work 34%
CPU: AMD Ryzen 5 1400 - 55.5%
GPU: AMD RX 580 - 70%
HDD: WD Blue 1TB (2012) - 46.3%
RAM: Corsair Vengeance LPX DDR4 3000 C15 2x8GB - 85.3%
MBD: MSI B350M BAZOOKA (MS-7A38)
Any help is appreciated!
Why would you upgrade to the 2600x when you could upgrade to the 3600?
I have a b350m motherboard and I dont know if its compatible or not. If it is and it doesn't bottleneck any of my other components ill look into it. I should reiterate that I have little to no knowledge about compatibility and such but from the research ive done online it appears that the 3600 isnt compatible.
For 144hz both gpu and cpu are in need of uograde.
What is your budget?
Id suggest an rx5790 or rtx2060 and ryzen 5 3600.
Yikes. Im kinda on a low budget as high as like 200$. I really hope that I would only have to upgrade one of my components. Im not looking to get ultra high settings and fps. I just want something that will allow me to run the newer games up to at least 60 fps.
