Hello Everyone,
Recently, in the last 5 days, my desktop has gone from operating perfectly well to now cutting power about once a day. I've searched the forums for a solution and plenty seems similar, but none of their solutions have fixed the problem.
Here is the build: https://pcpartpicker.com/user/zuesman101/saved/#view=twNZ8d
So, about 5 days ago, the computer completely cut power with no warning. No shutdown, it was like it was unplugged. It took about 5 restarts to get the computer to boot back into windows, usually it either didn't pick up the boot ssd or windows began infinitely loading. When I did get into windows, I would attempt to log in. After entering my pin it would attempt to load to desktop but would always take a minute and fail, bringing me back to the login screen. On the second try it always brought me instantaneously to the desktop. Once on the desktop, I would have about a minute of normal operation before windows "froze". If audio was playing I could still hear it, and video such as a youtube video would continue playing, but other than that everything would freeze (again besides video and audio playback). I would have about 30 seconds of mouse movement before the mouse would then freeze as well. About a minute later everything would return to normal. This would repeat about 1 to 2 times in the next 5 minutes before the computer would go back to fully normal operation. Some amount of hours later, anywhere between 8-16, the computer would cut power again and the process would repeat itself. One thing to note is that the 5 or so reboots were only needed the first time. Since then it boots on the first try every time, but all other problems repeat.
Any Ideas? Thanks in advance.
