WalkerGames :
you definitely are going to want to get a mid or full tower case. I personally think full towers are a bit too big in most cases. Almost every part you can get will fit in a nice mid case. Corsair, NZXT and Cooler Master all make excellent cases
$60~http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018&cm_re=corsair_mid_case-_-11-139-018-_-Product
$90~http://www.newegg.com/Product/Product.aspx?Item=N82E16811139044&cm_re=corsair_mid_case-_-11-139-044-_-Product
$130~http://www.newegg.com/Product/Product.aspx?Item=N82E16811139015&cm_re=corsair_mid_case-_-11-139-015-_-Product
Of course this is just Corsair, you can find awesome cases in this range from NZXT and CM like I said. Thermaltake makes descent cases as well. These are just the 3 brands I hole-heartedly trust
Iv been looking at the CM Storm Trooper/Stryker i really like the case due to its features but idk if the bang for buck is worth it. my build is not going to need that much space but i do want good airflow and i like the front panel specs. plus i could always expand, i just feel like the slots would be wasted. what do you think, should i go ahead and get it. i like how it has two 3.0s and two 2.0s, also the xdock, i could make a ssd as a off site backup. and it has the fan control.. but again its a little pricey, what is your take?
