Need help finding a graphics card
Since it is a touch smart pc you cannot upgrade it's graphic card. On the other hand that graphic card is fine and will play games at decent resolution but don't except heavy gaming on it.
The discrete card can be replaced. However, you're not going to find that particular card anywhere but HP.
yyk71200
877
If you send your PC to HP, they should be able to do it. You can't do it on your own.
