I recently purchased a new desk and I've kind of run into an issue that can be solved with a monitor mount but I need to find the right one.
This is the desk:
https://www.amazon.com/Studio-RTA-Producer-Station-Maple/dp/B0002F59JU
My issue is I have a 24" monitor that I planned to put on the top shelf, however I knew before I bought it that it would be probably be too high (I'm not that tall) and I dont want to have to 'look up' at the monitor. So currently I have it on the main desk area above the lower keyboard tray. This is ok temporarily, but I want to move it up a little higher. I'm trying to find the right mount that will do this. Ive seen a lot of arm mounts, but Ive had one of those in the past that I paid a lot of money for and after 6 months, it started to droop more and more and I had to toss it.
What would be ideal is a mount that sits flat on the shelf and clamps on the front and back (or only the back). This would place the monitor's height directly in the middle of the shelf, which would be the perfect height and then I could remove the monitors base.
Does anyone have any suggestions on what mount to use? I'm not opposed to an arm mount on the back of the desk that rests over the shelf either.
Thank you.
This is the desk:
Thank you.
