If you Google “System Interrupts” there are so many issues that come up. I have dug through many many threads of people who have similar issues as me. The issue arose from noticing my CPU usage spikes around 20-30% while at idle. This impacts many things from watching videos to playing cpu intensive games. I am pretty certain the issue lies with an out of date chipset driver. The problem I am running into is Gateway's crappy driver support. I have a Gateway FX6801-01. The only driver I can find from their site is for Vista. I downloaded it anyway to see what would happen and it absolutely will not install while using Windows 8.1.
I have found this site: http://www.driverscape.com/manufacturers/gateway/laptops-desktops/fx6801-01/97604
The site lists all the drivers for my chipset (seems like quite a bit), but I am not sure if I should install of them, some of them, or none of them at all.
Is Driverscape legit? This seems about the only option to attempt to fix the problem.
Sorry for the title gore, I really want to help other people who may have a similar issue.
