Need help finding replacement wires
Anthony_164
Commendable
Dec 25, 2016
I've looked for replacement wires with a male input and 2 male audio/mic for my sound blaster x headset. I've looked on ebay for replacement but I cant find one. anyone know where i could get me a replacement?
Are you talking about the cable with a female input and then the dual male connections like in this pic? That looks to be a standard 4 pole to dual 3 pole adapter, can find them in lots of places.
It should work, outside of the headphones having some special wiring. Cable should be about $5, cheap enough to try it. You should be able to get a male 4 pole to dual male 3 pole cable also without needing another adapter.
