[SOLVED] Need help fitting CoolerMaster Hyper 212
BPR96
84
Hello,
i am trying to install a CM hyper 212 evo on to my MSI tomahawk b450 max motherboard.
I am having a problem when trying to fit the 4 arm metal plate into the screws in the motherboard.
I have an issue where two corners will fit in but then the other two don’t line up correctly.
I have attached a couple of pics of the metal plate without the fan to show you what I mean.
any advice? Cheers
View: https://imgur.com/a/v3SIOkf
If it doesn’t fit you need to rotate it 90’
the HS has to be underneath the bracket or you’re wasting your time.
it’s also very likely you have the backplate inverted if you’re having issues
