Motherboard:
Intel S5000XAL LGA 771
GPU:
EVGA Geforce 210 x16
Let me know if you need more info. I'm hoping to do this asap. SO! If it will work and not break everything I will just cut my PCIe slot to make it fit 😀
Also the cards pinout is smaller then the entire slot but wont fit into any of the sections. Should I cut out the middle of PCIe slot?
I'll get an adapter if I have to!
GPU:
