Hello I am planning on building a pc on my own and i want to know if my pc will work well with all the accessories i am adding to it.
My PC will have the following: -
Graphic card: MSI radeon 480 gddr5 8gb.
Mother board: Gigabyte ga-z270x-ud3.
SSD : MyDigitalSSD BPX 80mm (2280) M.2 PCI Express 3.0 x4 (PCIe Gen3 x4) NVMe MLC SSD (240GB).
Processor: I7 7700k .
RAM: Corsair dominator platinum series 16gb.
HDD: WD 1tb.
Power Supply: Thermaltake rgb 850 watt.
Cooling: Corsair Hydro Series H100i v2.
Case: Corsair 750 airflow case.
I will mainly be using this pc for some games such as overwatch, black ops 3, for honour etc.
I would like to know if i would be able to run these games properly on stock clock/ overclock.
I also want to know if 850 watt will be enough for what i am using and i will also be adding a RGB LED strip onto my case.
And also do i need additional cooling because i think there are already 2-3 fans in the case and i will also be using the corsair water cooling for the CPU.
If any one of you by any chance may have done the same build (99% impossible lol) please share your review on it.
Thank you in advance!
Edit: This is going to be my first build so if any tips please feel free to drop your recommendation!
HDD: WD 1tb.
