J jbeemcdonalds Reputable Jan 19, 2015 76 0 4,630 Jan 26, 2015 #1 Hi im looking for a cheap mobo but will work perfectly for i5 4690k and gtx 970/960. i need to save some money for other things. Thanks for answering!
Solution mangodrinker Jan 26, 2015 The GIGABYTE GA-Z97-HD3 might fit your needs, although if you can stretch for the Asus Z97-A, that would be my recommendation.
Moonstick2 Distinguished Oct 3, 2014 830 131 19,590 Jan 26, 2015 #2 What's your actual budget? One thing is that you're talking about a -K processor implying you'l be overclocking, but that can be difficult to do on a cheap board. If overclocking isn't going to happen then you'll have more options on budget models. Upvote 0 Downvote
mangodrinker Honorable May 25, 2013 435 0 10,960 Jan 26, 2015 #3 What is your approximate budget? Thanks. Upvote 0 Downvote
J jbeemcdonalds Reputable Jan 19, 2015 76 0 4,630 Jan 26, 2015 #4 for mobo my budget is $100 maximum but if its not good i'll just save some money to buy a good mobo Upvote 0 Downvote
mangodrinker Honorable May 25, 2013 435 0 10,960 Jan 26, 2015 Solution #5 The GIGABYTE GA-Z97-HD3 might fit your needs, although if you can stretch for the Asus Z97-A, that would be my recommendation. Upvote 0 Downvote Solution
J jbeemcdonalds Reputable Jan 19, 2015 76 0 4,630 Jan 26, 2015 #6 Thankyou! i pick the Asus Z97-A for my build thankyou very much! Upvote 0 Downvote
