Well my pc felt fine when i got it. But after a while after using it got worse. Maybe i got a virus cause i have downloaded alot of shady programs.
Thanks for replying mate!
While a "Virus" is more unlikely, a whole lot of bloatware can do it ... fast. Basically, try to massively optimise Windows, which it needs anyway. There are many guides, and if you can not fully figure it out, we can help here (both on this thread, as well as in the Windows 10 subforum), but the general gist is the following:
- get rid of all the software you have not installed yourself and do not need/want/(know, but be careful on the latter).
- stop all the autostarts on all the software you do not actively need every single time you boot it up (and even then, try to keep it at a minimum. E.g., there is no reason Steam needs to autostart. You can turn it on when you want and then off when you do not need it).
- I do not use windows 10, so I do not know if this is still sound advice, but on windows 7, there is something called "msconfig", which you run in the "run prompt" (Win +R). There, go on services and startup and turn off things you do not need. BUT, many of these things are needed for windows to function normally, so be a bit careful. Google the things you do not know. That being said, you can always restore to defaults, so you should be fine, if you do not push things tooooo far.
- There might be similar things out there.
- Things like CCleaner (for the registry) are also nice.
For the termal throteling... install core temp and see the read outs. It should remain under 80° really (though 85 occasionally should still be permissible). If it is regularly over 90°, even without stress testing (ie., in normal gaming) thermal throttling might be a real issue.
As for the PSU. What kind is it? Do you know?
CAUTION:! If you decide to open the case and look at it remember! The PSU is by far the most dangerous part of a PC! So unless you know what you are doing, do not touch it etc (esp. anything inside.... never ever put anything inside the fan region
- Even before anywhere near it, REMEMBER TO DISCHARGE IT FIRST!. Discharging is done by unplugging the PC (out of the socket, if it is a laptop - remove battery too!) and than turning it on. The power light should go on for a split second, cause of all the energy still in the PSU. This amount of energy, though it seems small, can be deadly!, so again. Be careful with the PSU.
Best and take care.
