Question Need help for pc parts compatiblity
Oct 18, 2019
Hi everyone, this is my first time posting here so i don't know if this is the right category to post. I've done my research and i think that my build is compatible as is. but im a bit worried though since this is my first build, im afraid ill be buying the wrong parts. so i Just wanna confirm to the experts here if my build is really compatible with each other.
there was a notification though in pcpartpicker that i3-9100f does not have stock cooler but when i asked the store they said it has stock cooler.
and another thing is that my friend told me that i3-9100f tends to overheat so i was a bit worried and told me i should go directly to i5-9400f but im on low budget so i cant move on further i still need to buy the peripherals. so i also want to confirm this
PCPartPicker Part List: https://pcpartpicker.com/list/PZg8dm
CPU: Intel Core i3-9100F 3.6 GHz Quad-Core Processor ($91.77 @ Amazon)
Motherboard: Asus PRIME B365M-A Micro ATX LGA1151 Motherboard
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3000 Memory ($84.99 @ Newegg)
Storage: SanDisk SSD PLUS 120 GB 2.5" Solid State Drive ($27.15 @ OutletPC)
Storage: Toshiba P300 1 TB 3.5" 7200RPM Internal Hard Drive ($58.48 @ Amazon)
Video Card: GALAX GeForce GTX 1650 4 GB EX (1-click OC) Video Card
Ralston18
What is your budget?
As for the cooler - it should be included.
Reference:
https://www.legitreviews.com/intel-core-i3-9100-4-core-processor-review_213639
Do doublecheck the boxed model numbers. Get the store's response in writing - just in case.
And if all possible, save up, and install an i5.
Note: That 120 GB SSD is going to fill up too fast and too soon even if you are disciplined about storage space. 256 GB SSD is recommended.
WildCard999
Herald
The build is compatible but you may be able to do a bit better depending on the budget.
Instead of the small SSD & HDD just get a 512gb SSD to start with as it will be faster and save you some money.
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive ($62.49 @ B&H)
Total: $62.49
Generated by PCPartPicker 2019-10-18 12:17 EDT-0400
That PSU is terrible for the price, change it out.
Memory is also too expensive.
Missing a Case.
Oct 18, 2019
it's fine, i can get an i5 after my next 2 projects. i Just need the computer right away since i'll be using it immediately after building and i need it for work. my budget is around $800 with the monitor and peripherals. and for the psu i Just picked anything that has the same specs as the one in the list cause i can't find it but i assure it is legit same specs and it cost at least 59$. do i replace the ssd and hdd with just 1 m.2 nvme? i updated the list.
Motherboard: Asus PRIME B365M-A Micro ATX LGA1151 Motherboard (at least $109 local store near me)
Video Card: GALAX GeForce GTX 1650 4 GB EX (1-click OC) Video Card (at least $169 local store near me)
Case: Tecware Nexus M MicroATX Mid Tower Case (at least $37 local store near me)
Power Supply: AEROCOOL RAVE RGB 600W 80+ POWER SUPPLY (at least $59 local store near me)
Monitor: NVISION IP22V1 75hz (at least $77 local store near me)
OTHERS:
REDRAGON MITRA K551 OUTEMU RGB ($47)
FANTECH LEGION HQ51 RGB GAMING HEADSET($11)
SANDISK ULTRA DUAL DRIVE 32GB USB 3.1($9)
total: ( at least 778$) sorry took long i have to convert some part prices in dollars though.
@Ralston18 oops sorry it was i3-9100f but i think it's just the same though just no integrated graphics card?
@WildCard999 you got me thinking yeah maybe i should sacrifice it to get nvme, hehe thanks
WildCard999
Herald
You could probably do better with AMD Ryzen but for a 9400F build with peripherals under $800 this is what I'd get.
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor ($144.99 @ Amazon)
Motherboard: ASRock B365M Pro4 Micro ATX LGA1151 Motherboard ($74.89 @ OutletPC)
Memory: Patriot Viper Elite 16 GB (2 x 8 GB) DDR4-2666 Memory ($59.99 @ Amazon)
Video Card: PowerColor Radeon RX 570 4 GB RED DRAGON Video Card ($149.99 @ Newegg)
Case: GameMax Mini Kallis MicroATX Mini Tower Case ($31.20 @ Amazon)
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($81.99 @ Amazon)
Monitor: VIOTEK NB24CB 24.0" 1920x1080 75 Hz Monitor ($109.99 @ Amazon)
Keyboard: Cooler Master Lite L Wired Gaming Keyboard With Optical Mouse ($59.95 @ Amazon)
Total: $775.48
Generated by PCPartPicker 2019-10-18 12:56 EDT-0400
The monitor is Freesync so it will work well with the RX 570 which is also better in performance then the 1650. Monitor has built in speakers but whenever you get extra money get dedicated speakers or a headset.
Reactions: vMax
