Need help formatting hard drive please!
TheBeliskner
17
I have a Seagate 1.5 TB portable hard drive and have recently tried to format it. Now I'm not really good with all this tech stuff and I am having problems. The formatting process seems to be stuck in the middle. This is what it looks like on the formatting progress window:
Capacity: 875 GB (Why does it say 875?)
File System: NTFS
Allocation Unit Size: 4096 bytes
Restore Device Defaults
Volume Label: (Left it blank)
Format Options: Quick format and MS-DOS start up disk (Left both unchecked)
Then the progress bar which is seemingly stuck somewhere close to the middle. It hasn't moved for hours now and I'm getting worried. I tried to do a quick format but it says it couldn't be formatted. I need some help
wow you got a lot of partitions on there lol. Just delete all the "Other." And it should be unallocated after that. Then you will be able to expand it.
Okay, now right click on your 1.5TB HDD. And choose Convert to Primary. Once you did that, right click again and Resize/Move Partition. Then you are able to (hopefully) extend/expand the drive with your mouse if there is space left and right. Click OK and Apply. Then tell me the results.
Ok. I can't seem to expand the drive. There isn't space. I should say that along with my drive there are 5 other partitions (?) I don't know if this affects anything or not but I just thought you should know.
It shows up as my drive, Other, Other, Unallocated space, Other, Unallocated space
