Need help getting a 140 mm fan and lighting
419Recon
95
Alright so I am looking for a decent fan to use.
My case is the NZXT H440, I will have 3 Noctuas in the front, and two up top.
I am not sure what fan to use in the back as most noctuas aren't nice looking and that's the one I would have to look at.
I came across the NF-A14 iPPC-3000 PWM, will that work?
If not, what's a good reliable fan to use, preferably not LED.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608048&cm_re=noctua_140mm-_-35-608-048-_-Product
Also, I am wanting to get an RGB lighting system and had planned on hue, but since it's not compatible with H440, what would you recommend? Are Ebay LEDs trustworthy?
Here's my build http://pcpartpicker.com/p/Vftkbv
Edit: Or should I just try for water cooling?
Alright, I will probably go with that.
Oh I gotcha' sorry it was late and I misunderstood.
I'm probably going to pick your last answer as the solution. But I wanna thank everyone who replied, you all really helped and I really appreciate it. :)
