I'm having trouble getting my monitor to 60htz at 4k. Iooked up some solutions and got two DP to HDMI cords that are rated for 4k@60. I didn't realize that they were "unidirectional", so the cord that goes from my capture card to the monitor doesn't send out any signal.
My question is how do I get 4k60 on my monitor while using my capture card? Is there an adaptor(s) that would work? Other cables?
I heard that I could try mirroring my display(dp cable going to my monitor, and another cable going to my capture card IN and nothing in the OUT") but I don't know how much more strain that will put on my GPU.
My GPU is a 2080ti with 2 DP ports and 1 HDMI( not sure if it's 2.0 or not)
The Capture card is a Razor Ripsaw HD( specs say it has 4k60 passthrough with two HDMI 2.0 ports)
The monitor is a Acer Predator XB1( one DP 1.2 and 1 HDMI that isn't a 2.0)
Any help would be very much appreciated!
