So my PC had some virus called "Windows update service.vbe." I found it startup menu and disabled it. Then I right clicked it and selected "Go to file location" and deleted the file.
Now the "Windows update service.vbe." is gone from the startup menu but there is something called "Windows" in its place.
View: https://imgur.com/a/ntTrL0Y
It doesn't give me the option to got to file location. It gives me the enable, Search online options only.
View: https://imgur.com/a/uWbfgaZ
As you can see, the GPU is being used when there is no game/app open.
What do I do?
What do I do?
