Here is the story. (and yes, I looked at every post in the world about this and still no answer... I even asked my mobo manufacturer)
I recently installed a new GPU after just using integrated from the A10 7870k
Once that happened, I gained hardware reserve memory, which was around 6GB.
Went into the bios and turned off the shared memory with my integrated r7 graphics. Now the hardware reserve is 4.3GB and so I have 3.7GB available...
Problem is, I can't run most of my programs with so little memory.. If I am going to have 8GB of memory, why not use all or most?
So I kept reading posts and noticed that this is the motherboards compatibility with the brand I own. I have a gigabyte A88x mini wifi mobo and I have been using it even before I put in the new gpu and my memory is Corsair 2x8gb Vengeance Pro 1866mhz.
So does anyone have any idea how I can fix this issues? Because im just completely lost.
Also, I checked the memory sticks and they are secure and in place (haven't touched them in a while, but hey? why not check).
A response would be great!
Thanks, Jesse
Thanks, Jesse
