[SOLVED] Need help identifying my current PC case!
Nov 24, 2020
4
Hi!
Could someone help me figure out which case I'm currently using? I couldn't find any indication of the brand on the case; no logo, no labels, nothing.
I bought it used back in 2017, so it's not a very new case. I figured that the shape of the window would've made it easier to find online, but no luck there.
Here's a link to some photos of the case (don't mind the stickers): View: https://imgur.com/a/dPHIke6
Any and all help is greatly appreciated!
This is the most similar looking one i found. It just doesnt have the sidewindow and ist missing 2 front panel USB 2.0 ports
https://www.jj-computer.com/artinfo.php?artnr=V0000134
It does look very similar, yeah! The one I have doesn't also have the logo on the front panel, but I'm thinking this must be from the same manufacturer. It can't be a coincidence that these two look so similar.
Thank you for the reply! 👍
Look inside the case.
Sometimes there is a serial number or other info printed inside.
I've seen most of the inside area already, as I open the case up to clean it somewhat regularly. I guess the label could be in a sneaky place, like behind the motherboard. I'm not sure if I remembered to look behind it the last time I changed the mobo, but I'll scour the case for any labels the next time I'll take it apart.
I also found one without the Logo and it also has the front case fans. But i still did not find one with the sidepanel.
https://www.jj-computer.com/artinfo.php?artnr=V0000133
Could it be some kind of custom built one?
I suppose it's a possibility. I also found a third one with a weird contraption on the side, and it's just as close, if not closer to my version as the other ones:
http://www.computex.biz/joujye/defa...ageType=ProductDetail&ContentTab=Introduction
That one is also missing the side window, so I'm pretty much out of ideas here. I'll check for any hiding labels the next time I'm taking the PC apart, but other that that I'm willing to accept that this case will be an obscure one with possibly no accurate model number whatsoever. That's technically an answer to my question, even if I was expecting some kind of product page or familiar brand to be found. Many thanks for helping me out!
