Need help in my first pc build
BOTTL3N3CK3D
Commendable
Mar 14, 2017
17
I'm going to do my first pc build and i'm not sure if these parts will work.
AMD Ryzen 5 1600
MSI B350 Tomahawk Arctic
G.Skill Trident Z rgb 16gb 3000 mhz CL15
Nvidia gtx Titan 700-series (I got it from a good friend of mine, and i will upgrade it later to a gtx 1070 maybe)
Silverstone 875 w psu (I got it also from my friend)
Phanteks p400 tempered glass edition
Samsung 850 evo 250 gb SSD and a WD blue 1 tb HDD
Also what version of windows should i buy? There is windows 10 home 32/64 bit usb which is 119€ and windows 10 home 64 bit oem which is 129€.
Should be good. However I'm not sure if G.skill software works on ryzen boards (to change colors on ram) already - but even if not, they are most likely going to make that work soon.
EDIT: it already works on X370 boards, so B350 should be next.
As for windows, go for first one.
