Hello guys! After running cinebench, I managed to get this data with overclocking my Core 2 Duo E6750 @3.2GHz with a Gigabyte EP45-UD3L motherboard, 4GB 800MHz Kingston RAM, a generic power supply and a stock cooler that came with the processor.
So here it is:
At stocked speed 2.66GHz
CPU = 125 cb
OpenGL = 41.06 fps
Temperature © = 44C idle, 65 max at full load
Overclocked @ 3.2GHz
CPU = 150 cb
OpenGL = 44.32 fps
Temperature © = 50C idle, 74 max at full load
So what do you think guys? Is it worth it to overclock or should I just stay as it is? Also if you would recommend me to overclock, I might get some aftermarket cooler maybe the deep cool ice blade since that's the cheapest cooler I found. And assuming I would overclock it and I buy deep cool ice blade, can I run it around 3.5GHz without running over 70C? Thank you so much guys.
So here it is:
CPU = 125 cb
OpenGL = 41.06 fps
CPU = 150 cb
OpenGL = 44.32 fps
