Yes will work fine, and the difference between single and double fan is probably size and noise, where the double fan one should cool a bit better and make less noise. Both will do fine, but if you have the space in your case get the double fan one.
Also I guess you're aiming for an i5 6400+gtx 1060 build? That will work just fine no issues.
