[SOLVED] Need help in updating bios of motherboard
Cmjf 1212
5
Hi. I have Asus prime h310m e motherboard and i want to upgrade the bios of motherboard to install i5 9600k processor but my operating system is installed in ssd and normal files is installed in hdd so how to update bios and what precautions should I take to successfully update my bios like I have heard not to update bios while SSD is there as main drive or to unplug all other drives while updating bios and to set xmp profile to default so are there more such precautions I should take and whether I should update bios when ssd is the main os drive coz i want to successfully update bios with no part failure
Specs
Cpu- pentium G5400 8th gen
Gpu- GTX 1050ti
Ram- Corsair vengeance 2 x 4 gb ddr4 2400mhz
Motherboard- Asus prime h310m-e
PSU - antec atom v450 450 watts
Ssd- wester digital wd blue sn 550 nvme 500 gb
Ssd- Kingston A400 240gb
Hdd- 500gb sata hard disk drive
it doesn't help manual doesn't show bios update procedure - https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/PRIME_H310M-E/E13885_PRIME_H310M-E_UM_Web.pdf
but its likely on the advanced/tools menu in bios
i am not sure about the need to remove ssd, it shouldn't make any difference.
BIOS updates reset the settings in the bios so resetting XMP before running an update is probably not needed.
ssd unlikely to fail if attached, most that might happen is bios can't see it at startup as its possible the boot method you have is different to default. But you should be okay.
9600K requires bios level 2201
Check with cpu-z mainboard tab to see if you are at that level now.
The normal and best way to update a bios is via a usb file, not via the internet.
USB avoids the possibility of interruption because of windows or internet issues.
You would download the bios file to a fat 32 formatted usb stick.
Then boot to bios and select the bios flash option.
When flashing a bios, have patience.
It may take 5-10 minutes without any evidence that anything is happening.
Interrupting the flash may lead to a complicated recovery process.
There are several youtube posts on the process.
Here is one:
View: https://www.youtube.com/watch?v=UlSWryy_kKI
