Need help knowing what to overclock to
ThrowinCards
134
I have a intel i7 4790k running at stock speed what should i over clock to and how do i over clock i have an asus mother board whats the program that comes with that, that will allow me to be able to over clock?
Overclocking is very much trial and error. You increase the speed by small margins and then test to see if your system is stable. If it remains stable, then you can increase it again by a small margin and retest. You continue this process, incrementing by small margins, until your system fails a load bearing test; at which point, you down-clock to the last stable point you previously tested.
I found this article which may help you.
-Wolf sends
-Wolf sends
Well be sure not to overclock too much or you will lose performance, also you can search up how to overclock on youtube and you will find many tutorials how to overclock. But i suggest you not overclock anyways your cpu is @4ghz but if you want to i can give you some help..
Your motherboard UEFI Bios comes with an oc tweaker tab did you know that?
also search up this program its called Asrocks Atuning software did you motherboard come with that?
i got my information from here
http://www.overclockers.com/asrock-z97-extreme6-motherboard-review/
